2006 GS300 transmission
Could be as easy as a clogged filter. Or it could be the famous Toyota 1st to 2nd shift solenoid has begun to fail.
If the tranny fluid is brown or darker I'd opt for a fluid change and see if that solves the problem. But first make sure the fluid level is correct by starting the car, set the parking brake, put the tranny in neutral and check the dipstick for proper level of fluid.
