2013 RX350 rear cargo door issue
The rear cargo door opens and closes automatically using the dash button or the fob.  The door will lower automatically (once it has been raised manually) using the button on the bottom of the rear cargo door.  The door will not raise automatically if I push the black rubber switch cover located under the tail light.  Rubber cover appears to be in good shape.
Something is not working.
For my 2011 RX350 this is normal operation:  The switch under the handle will unlock all doors - including hutch - but the hutch needs to be manually raised.
