Front end shaking
Bobboo
Have you had your rotors turned? I’ve found previously when I brake and the front end shakes, it’s because the rotors have warped. They turned the rotors and the shake stopped and it braked smoothly.
  • 6 months later...
I had this problem.  Replacing the larger lower control arm bushing actually reduced this shaking significantly before I changed the rotors.  Then I changed the rotors.  I am also going to replace the steering rack bushings.  I have a feeling one of them is giving up based on the feel of steering and my past experience.
  • Like 1
