BoomerBikes Posted April 24, 2021 Share Posted April 24, 2021 The air intakes on our NX face upward and lots of debris from our pines collects on them. The small brown worm-like things in the photo are male pine cones that drop off the tree in the thousands after releasing their pollen in the Spring. The big woody cones are female, with seeds. On our old RX, these blocked the intake vents, inside, and when we had rain, water flowed in through the air filter behind the glove box (lots of these cones in there) and flooded the carpeting. Lexus couldn't figure out where the water was coming from (offered to replace condensers, evap, etc.) until a really good repair shop knew about this issue. They disassembled the vent and cleaned out the intake. Problem solved. So...can I check and cleanout the intake on the NX? No problem yet but I want to ahead of it. I do not see an obvious way on how to dissemble or look in there. Thank you. Quote Link to comment Share on other sites More sharing options...
Bykfixer Posted April 25, 2021 Share Posted April 25, 2021 Maybe take a garden hose to the car and run water out of the end with no nozzle and see where it comes out, probably near the door hinges. Place spray nozzle over the end and spray up and into where the water exits from when your tree is dropping all those pollen pistols. Mrs Fixer parks under a willow oak and we found that to work in spring. 1 Quote Link to comment Share on other sites More sharing options...
Lexus Owners Club Posted April 26, 2021 Share Posted April 26, 2021 Another method to establish point of entry for debris is to use a Smoke Generator which allows smoke to enter from within the car and can easily be seen to exit through holes, grilles, etc Quote Link to comment Share on other sites More sharing options...
