Big G Posted May 10, 2004 Share Posted May 10, 2004 Hi All, i just bought my 93 GS300 and I came from a 5 speed Z car. 1. I am not sure when to keep the overdrive button on. I did notice the RPM change when it is off. Does it act like a 5th gear? 2. What will save me more gas and car repairs? Overdrive on or off? In Southern Cal, we try to make gas pump stops as least as possible :) 3. The console button "Normal/Power (I think)" What are those functions? I have the book (CD) for the car on order and when it arrives, I hope to understand more. Thanks, Gilbert Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted May 10, 2004 Share Posted May 10, 2004 Gilbert, I as well as most car makers recommend that you leave the overdrive engaged always. The only instances you may want to turn it off is when going down a steep slope to help you slow down a bit, or when driving up and down in hilly regions. Yes it is like an extra gear. The PWR/Norm button will change the shift patterns for more "sporty" driving in PWR mode. The revs will build a little higher before shifting. Norm mode with overdrive on will get you the best gas mileage. Quote Link to comment Share on other sites More sharing options...
Big G Posted May 10, 2004 Author Share Posted May 10, 2004 Thanks Guy, I appreciate you. I also want to thank the forums for the valued information. Gilbert Quote Link to comment Share on other sites More sharing options...
