I have been searching online for some prices for front and rear replacement strut assemblies for my '95 ES300. I have come across several different websites that feature a "Touring Class" replacement strut. However, this strut is for the rear only.
I was unaware that Lexus made a Touring model for the ES300 (similar to the Infiniti I30t?) Is this a real model? Are these shocks any different than the regular ones as far as performance (I would assume a bit stiffer?)
No, there was no touring edition, its probably just a specific strut upgrade.
You're probably right, but what's the difference?
KYB makes the OEM struts that I have seen, but Bilstein makes the "Touring Class" strut. The Bilstein is cheaper than the KYB (don't know if that makes a difference or not).
The Bilstein(Touring Class) replacement strut for the ES has slightly different valving then the standard OEM Lexus part. It'll give you a firmer ride.
I found out that Bilstein does NOT make any aftermarket struts or shocks for any model ES's! They do however make shocks for certain years of LS, GS, and IS Lexus's.
branshew-
The link on your previous post is dead! :rolleyes:
I spoke to the Autoparts Authority and was told that their listing for Bilstein 1996 Lexus ES300 V6, Strut Assembly Touring Class, Rear - Right is INCORRECT! They do have the normal replacement struts (KYB) for the '96ES though.
Once again, as I said in a previous post: I found out that Bilstein does NOT make any aftermarket struts or shocks for any model ES's! They do however make shocks for certain years of LS, GS, and IS Lexus's. ;)
