HelpPlease Posted September 12, 2020 Share Posted September 12, 2020 I disconnected battery and locked doors manually because having problem with battery kept dying, wanted to see if it was battery or it was something else. I locked door manually. Now key won't let me open door. what can I do. Quote Link to comment Share on other sites More sharing options...
RX400h Posted September 21, 2020 Share Posted September 21, 2020 How old is the battery? Reconnect it to see if you can open the door. But really, the first thing I would do is to take the battery to Costco or an auto parts store and have them charge and then load-test it. If the battery is deemed to be good or is bad and is replaced, have your alternator tested with the battery installed. My guess is that the battery needs to be replaced but depending upon the number of miles you have on the odometer, the alternator could also cause the battery to drain over time. Quote Link to comment Share on other sites More sharing options...
mad400h Posted March 22, 2021 Share Posted March 22, 2021 Hi, I'm new here and have a problem with 2008 rx 400 h. Battery goes dead after not being driven for 3-4 days. Anyone figure out a fix? thanks Mike Quote Link to comment Share on other sites More sharing options...
RX400h Posted March 24, 2021 Share Posted March 24, 2021 1. How often and for how many miles do you drive the vehicle? 2. How old is the battery? 3. Are both battery terminal clamps tight? (You should not be able to rotate either clamp.) Quote Link to comment Share on other sites More sharing options...
mad400h Posted March 28, 2021 Share Posted March 28, 2021 Hi Dave We don't drive it much, retired. The battery and charging system checked good. Terminals are clean and tight. Has a lexus battery. We bought this last year with around 67,000 miles, lexus report showed battery had been replaced 4-5 times. Thought this was because not driven much. Thinking of getting a battery quick disconnect, used one before. Have the battery negative cable off now until going to drive it again. Any ideas? How about a trickle charger? Thanks Mike Quote Link to comment Share on other sites More sharing options...
RX400h Posted March 29, 2021 Share Posted March 29, 2021 Mike have you thought about having the dealership investigate this? Quote Link to comment Share on other sites More sharing options...
TomRX Posted April 2, 2021 Share Posted April 2, 2021 Disconnecting the battery every time you leave your car for a few days is not a good idea. You have to reset the power windows and maybe some other electric components after the battery has been reconnected. In my opinion it is a better way to use a digital battery charger during the time car is not in use. Doing so you avoid the battery drainage problem. Quote Link to comment Share on other sites More sharing options...
