lozano175 0 Posted June 7, 2020 Report Share Posted June 7, 2020 I was doing the DIY replacement of a radiator and I accidentally unscrewed the front AC condenser line which I though was part of the radiator. This caused coolant to spray out. I was able to get it to stop but some did leak out. Did I cause any more damage that I may not be aware of or was !Removed! the bolt back the simple fix? I have no idea what it looked like before but it does not look like it is screwed back in all the way. Should it be flush? Quote Link to post Share on other sites
RX400h 25 Posted June 18, 2020 Report Share Posted June 18, 2020 If it doesn't leak and you didn't lose much liquid, I would suggest that you monitor it for a while before getting too worried. Quote Link to post Share on other sites
lozano175 0 Posted June 21, 2020 Author Report Share Posted June 21, 2020 If you look closely at the picture, where the two pieces connect, there is a gap that didn't close correctly because of the pressure coming out. If i unscrew it, will I be able to tighten it correctly with the pressure coming out or do I need to let it completely drain out? Quote Link to post Share on other sites
RX400h 25 Posted June 23, 2020 Report Share Posted June 23, 2020 I think it'd be worth a try, although it's hard for me to believe that the static fluid pressure is high enough to do this. Quote Link to post Share on other sites
Matt burk 0 Posted July 11, 2020 Report Share Posted July 11, 2020 My emergency brake keeps getting stuck when you push it down having a hard time releasing it anybody know any tricks. Or is there something I'm just not doing right Quote Link to post Share on other sites
