What does this combination of cel codes point to?
helmetless_stig
18 minutes ago, helmetless_stig said:
1999 LS400 with air suspension
Codes: P0171, P0715, P0710
Sometimes the cel goes off for a few days but it's been on lately for a while.
I know each of these codes alone could have many causes, but maybe someone sees a common source here?
Thanks
What are the names of these codes?
1 hour ago, helmetless_stig said:
P0171: System too lean Bank 1
P0715: Input/Turbine Shaft speed sensor A circuit
P0710: Transmission fluid temperature sensor A circuit
I am sure some people here can help you better. But I will suggest to change transmission fluid & filter.
Thanks
The most immediate code is the P0710 nd this is what I found on that issue.
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/855609-1998-2000-ls400-transmission-temperature-sensor.html
