Zett123 1 Posted January 23, 2020 Report Share Posted January 23, 2020 For do-it-yourselfers on removing the front wheel bearing hub on a LS460; I know removing the hub can be a problem due to the Galvanic corrosion between the two different metals causing them to bond. This making it a grueling task to separate the bearing hub from the spindle knuckle. My question is, has anyone tried to back the bolts that secure the hub to the spindle knuckle about 1/8" (or whatever) and then drive around the block making some nice, tight left hand turns (for right side removal) including traversing some speed bump,to loosen the hub for easier removal? I'm not talking about a three day excursion, I am just suggesting enough travel and stress on the components to jar it loose. Has anyone ever tried this? Quote Link to post Share on other sites
