• ×   Pasted as rich text.   Paste as plain text instead
  • Similar Content
    • By Dylan Schultz
      i have a 98 ls400 with about 244,000 miles on it. I’m having this very odd issue with the car. When I come to a stop light/ sign, the battery light comes on, rpms drop straight to 0 and the engine dies. Air and radio some times stay on. If I put it in park and restart the car the light goes away then its fine to drive until.. ya guest it I come to another stop. It does the exact same thing over an over at each complete stop. I assumed it was the alternator and I replaced it yesterday. No battery light, or weird idols happened for about a day. it is back to doing the battery light thing. If anyone has any Ideas of what it could be, or how to fix this issue id really appreciate it. ALSO not sure how old my battery is, changed the negative battery terminal when I did the alternator. Positive could be the problem (Corrosion on positive terminal) or maybe the terminal cable(s)?? Im very new to working on cars and any information is appreciated and retained.
    • By car_hacker
      I plan to buy RX450h soon. It is hard for me to afford new one, so, I'm looking mostly on '15 - '18 models with about 30K mileage.
      I never had a hybrid before. Is it a good idea to buy a used hybrid at all? I noticed that RX350 has much more offer on the secondary market than RX450h. Am I making a mistake buying a used hybrid?
    • By FinallyFree
      Retiring at 68 and thinking of selling my Honda Odyssey and getting a true Luxury car; a Lexius.  Zeroing in on an older ES 350 or RX.  Maybe even a Hybrid one.
      So, I ask you experienced Lexus owners, is this a bad Idea for a single woman who can’t fix her own car?  And the closest Lexus shop is 2 hours away?
      I’d like to keep the price around 25,000 or less.
      Thank you for any insights, advice, etc
      Pam
    • By Jlogo1985
      I just got a 2007 Lexus gs350 from my cousin he got a new car so the car was sitting for 5 months when I went to start it no surprise the battery was dead I called aaa to jump when he had the charger on the battery it started and everything was fine but when you shut the car off it wouldn’t start again so I had it towed to Toyota and had the battery replaced they said they changed the battery and now the alarm won’t stop going off and the key fob isn’t opening the doors or trunk when you go in the car the computer gps starts up but car won’t start or turn off alarm I changed the key fob battery before I had all the issues I’m not sure if this is the problem but Toyota could not figure it out and I just spent $400 for them to tell me good luck get out of here I was hoping you guys could help me out please!!!
    • By Andy_N
      Hi Guys,
      Couple weeks ago, my Lexus hybrid system light came on. I took the car to a  local Lexus dealer. They charged me $160 just to test the engine light and  told me to replaced my hybrid battery for $6,700. I am so broke I declined the replacement.  Last week, I opened the hybrid battery and tested all cells. Turns out all cells are fine. I reassembled the battery back in place and drove it for another week. Today while driving 70 mph on the highway the "warning hybrid light" comes on again  including check VSC, check ECB. Does anyone here has the same problem like it do? I know the battery is fine. Could the battery converter causing this problem?
      Any advise would be appreciated.
      Thank you.
