Battery Issue
Birmingham AL
Installed a new speaker in my front door and was running the sound system at volume to check for rattles. Ran less than 5-10 minutes when it cut out, nav display went blank and it was dead. Hooked up a battery charger. After 10  minutes I was able to start the car and I was back in business.
Does the system pull that much current or do I have a bad battery?  I had it checked 2 weeks ago during service and they told me the battery checked out fine.
Car seems ti start fine now, as well
Any thoughts?  Thanks in advance.
  • 7 months later...
Seems you may have a weak battery OR a poorly charged battery due to many very short trip  .  Check battery voltage with a volt meter when car has been off for a few hours. Google it.   Then you get a good grip on charge level.  For my battery type . AGM type battery ca 12.60 V means 75% charged.
This is about what you should preeferably be at least for the battery to last.
