Audio Door
What should I expect to pay for a new audio door motor?  My 2007 SC's audio door does not work.  I assume that a Lexus dealership will be very expensive.  Any ideas?  Is it a DIR repair?  Thanks!
  • 6 months later...
I have 07 that I had to replace the audio door on as well. I found a replacement (used audio door and motor) on eBay for a little over $100 if I recall correctly. I replaced the motor and swapped out the door as it was lighter wood then the original and it has worked just fine ever since. good luck!
