tommy34 Posted January 3, 2020 Posted January 3, 2020 I have a 2009 Lexus es 350. 7weeks ago I left my lights on for about an hour I came back saw dim lights the battery had given up. so I was given a jump start. After that, I have had 4 jump starts. if the car sits out for a while it struggles to start or won't start. Or if I turn it on and turn it off after a minute I would need a jump start. I thought it might be the weather but it's been about upper 30f to 50f degrees that is not terrible I belive because 12months ago I was riding the snow just fine. today 1/3/2020 I had to jump-start it about 5 pm pacific time FYI (dashboard lights working fine foglights on. ) felt like the battery had no enough power. the last time I drove it was yesterday 1/2/2020 about 8 am. with that in mind, I went to Autozone battery is good and the alternator is good according to the device I saw it myself self and I even purchased a battery tester well a cheaper one and on my end, the battery looks good so as the alternator. so I became curious and bought an OBD Scanner the Walmart one (Hyper tough OBD Scanner) for 20 dollars long story short it gave me the above 3 codes (p0345 p0365 p0390 07e8 engine) P0345- Camshaft Position Sensor A Circuit Bank 2 P0365- Camshaft Position Sensor B Circuit Bank 1 P0390- Camshaft Position Sensor B Circuit Bank 2 FYI(No check engine light no light at all) Does anyone know what this could be and why? fluid leak or just bad camshaft sensors?
rebeccaril Posted October 31, 2022 Posted October 31, 2022 did you figure out the problem? I have the same issue. Changed the camshaft sensor in both banks (before some research) .. looks like it is the computer (pcm or ecu) but could be a fuel sensor. I was just wondering what you came up with. I am a single mom of a college sophomore and a 7th grader. Trying to come up with the best solution and do it myself. I was thinking about resetting the computer, but did not want to have to reprogram it after.
