Wind noise
MidwestLS
Does anyone have experience with reducing wind noise on their LS430?  I have a 2006 UL with 93k that has been garaged.  The door seals feel soft and don’t look squished down with age.  While the car is generally quiet there is wind noise at highway speeds - not too bad like there is an obvious leak but it’s there.  The noise is mostly around the leading edge of the front windows and maybe the A pillar.
I was thinking of replacing the door seal or window weatherstripping. Has anyone seen an improvement and if so, which seals, strips or gaskets did you replace?
Tom
  • 4 months later...
I have the same problem with my '05 LS430. It appears to be coming from the right side back window, but i've not yet been able to isolate it. Sorry, no remedy yet.
