I have a 2011 Lexus LS460 AWD and I need replacement front lower control arm parts. The dealership says $1,400, which is ridiculous so I have taken to the internet to find some. However, I seem to have tremendous difficulty finding any control arms for the AWD variant. So, I'm left asking for help on here. If anyone can point me in the right direction that would be much appreciated.
to clarify, I need all 4 front lower control arms, passenger and driver side.
any help is appreciated
- Merry Christmas
Link to post
Loading...
  • Similar Content
    • By Snappy1
      Just finished replacing the front bearings and hub assembly on my Lexus Gx470. Many important things were learned. First is that you can buy the hub assembly and bearing assembly separate ......don't .    Next was the fact that there is a seal between the two assemblies that is not discussed anywhere. Then there are the 4 hub bolts that you must have replacement in hand otherwise you have to press apart the old assembly to get them. Then you need to know that there is an o ring as well. This can probably be saved but don't forget to look for that. Parts stores don't seem to sell the COMPLETE assembly.   However the good news is that Bluepit Bearings DOES sell the whole smack. $280.00 for that .  Trust me , if I ever do another bearing and hub replacement ,  this is the only way to go !  It will make this nightmare job about a thirty minute deal. And no, I do not work for Bluepit
