rxprime Posted May 4, 2004 Share Posted May 4, 2004 Does anyone know where the fuel filter is located in the 2000 RX300? Has anyone actually replaced this yet and how easy is it? Thanks. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 5, 2004 Share Posted May 5, 2004 beside the brake booster easy to change hardly ever done if you live in a city and use name brand gas stations that are pretty new. Quote Link to comment Share on other sites More sharing options...
Fern Posted May 6, 2004 Share Posted May 6, 2004 I'm under the impresssion the rx300 fuel filter is in the fuel tank and is lifetime. Quote Link to comment Share on other sites More sharing options...
rxprime Posted May 6, 2004 Author Share Posted May 6, 2004 I tried looking for it around the area where the brake booster is, but I did not see anything that looked like a fuel filter. Is it in that area behind the air filter housing? Well, if it is in fuel tank and lifetime, I guess that's good because it is one less item to worry about when doing routine maintenance. Thanks for all your input. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted May 6, 2004 Share Posted May 6, 2004 No filter is liftime or it wouldn;t be a filter. The reason you can;t ind the filter is because it is rather large as filters go. There is a sump screen in the tank but that is it as far as filters in there go. It is about 2.5-3 inchswide and tucked under the booster one side has an out and the other and in.They almost never need to be replaced. Follow the fue line from the fuel rail back and you;ll see it. Quote Link to comment Share on other sites More sharing options...
