ChopsLS430 1 Posted September 19, 2019 Report Share Posted September 19, 2019 So I've had this happen about 3 times now in the past week or so. When I get to my destination and turn off the car, it will not release the key from the ignition. I have to start and shut off the car a time or two more before it will eventually release the key. Any thoughts on this? I have also been noticing that the transmission (usually when it's cold I think), when it's shifting into 3rd gear (at low rpm and light throttle), the rpms shoot up several hundred rpm at the shift point, like it's slipping. Maybe just a transmission flush? When the engine is cold, it idles silky smooth. You can't feel it at all, though once at full operating temp, there's just the slightest, and I do mean slightest bit of vibration at idle. Lastly, very rarely, but it does it, I can hear a tiny bit of pinging under moderate acceleration. It doesn't do it all the time, only sometimes. And yes, I use 93 octane. If you can give me your thoughts on any and all of this, it would be greatly appreciated! Many thanks in advance! Quote Link to post Share on other sites
ChopsLS430 1 Posted September 26, 2019 Author Report Share Posted September 26, 2019 Wow... Quote Link to post Share on other sites
