Nic Posted May 3, 2004 Share Posted May 3, 2004 :( Both the left and right side mirrors do not work. I have removed connector on door armrest, but am in desperate need of wiring info for the connector. The connector has six wires on it, and none of them seem to be carrying power or ground!!. I have checked obvious fuses and they are OK. Help please. Quote Link to comment Share on other sites More sharing options...
AWJ Posted May 3, 2004 Share Posted May 3, 2004 I'll see what I can dig up. Give me a couple days though. Unless someone else has the info. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 3, 2004 Author Share Posted May 3, 2004 Appreciate it, AW. Quote Link to comment Share on other sites More sharing options...
Bubbles Posted May 4, 2004 Share Posted May 4, 2004 I have heard that this Power Mirror Computer Control box is the culprit. It is located behind the dashboard next to the steering wheel column; the area above your right leg while driving. My mirrors don't work either so I tried to save the 2 pounds by taking it off, but after an hour of working upside-down I gave up and left it there. Many people just buy a used computer box and zip-tie it to the existing box and swap over the connections. Quote Link to comment Share on other sites More sharing options...
slidermike Posted May 6, 2004 Share Posted May 6, 2004 Anybody have any more ideas? I have the same problem and would like to fix it. How about part #'s of the "control box" mentioned by bubbles? Quote Link to comment Share on other sites More sharing options...
Sadistic Posted May 6, 2004 Share Posted May 6, 2004 My sources don't list a part #, which means... I don't know, but it says 1.5 hours for install. An hour and a half under the dash usually means it could be a nightmare. Quote Link to comment Share on other sites More sharing options...
