Bob Wing Posted July 12, 2019 Share Posted July 12, 2019 I converted my LS460 AWD from air Struts to Coil spring struts. I started the car while the front of car was raised now the High Hight light flashes and i get the message to have the dealer check the air suspension. How do i re set the codes? I disconnected the battery several times? Quote Link to comment Share on other sites More sharing options...
RCD-BC Posted June 23, 2020 Share Posted June 23, 2020 Hi Bob! I have a 2008 LS460 Stk. With coil spring shock combo. I love the car but want to tighten up the barges suspension a bit with stiffer aftermarket spring shock upgrade? Was you conversion to stk coils or did you go aftermarket and how was the change overall. Would do it again or bad decision. Thanks Randy Quote Link to comment Share on other sites More sharing options...
