Pilsen Posted April 17, 2019 Share Posted April 17, 2019 This pass weekend as I was driving at 40 mph this lights went on my dash , as you can see in the pictures my car has only 40000 miles , could anybody give me an advise or should I just take it to the dealer? Quote Link to comment Share on other sites More sharing options...
Lemmy Posted April 17, 2019 Share Posted April 17, 2019 Oh God! Abs pump? I just bought an 08 gs460. This possibility almost changed my mind. I hope its something other than that my friend. Quote Link to comment Share on other sites More sharing options...
Johnathan Branch Posted October 21, 2019 Share Posted October 21, 2019 was at Toyota dealer with brake and abs light on and they told me I needed a brake Actuator and accumulator. I researched the forms of Lexus and seen that it was a known problem. Codes: C1241 LEXUS Meaning If there is a problem with the brake actuator assembly (Skid Control Electronic Control Unit) power supply circuit, the skid control ECU outputs the Diagnostic Trouble Code(DTC) and prohibits under the fail safe function. C1391 Lexus Description The Diagnostic Trouble Code (DTC) is stored if a brake fluid, internal or other leak is detected due to improper sealing in the actuator. Quote Link to comment Share on other sites More sharing options...
