07 LS 460 vsc , abs , brake system failure dash lights
This pass weekend as I was driving at 40 mph this lights went on my dash , as you can see in the pictures my car has only 40000 miles , could anybody give me an advise or should I just take it to the dealer?
  • 6 months later...
was at Toyota dealer with brake and abs light on and they told me I needed a brake Actuator and accumulator.
I researched the forms of Lexus and seen that it was a known problem.
Codes:
C1241 LEXUS Meaning
If there is a problem with the brake actuator assembly (Skid Control Electronic Control Unit) power supply circuit, the skid control ECU outputs the Diagnostic Trouble Code(DTC) and prohibits under the fail safe function.
C1391 Lexus Description
The Diagnostic Trouble Code (DTC) is stored if a brake fluid, internal or other leak is detected due to improper sealing in the actuator.
