dommm Posted April 1, 2019 Report Share Posted April 1, 2019 I just change my old tires for new Michelin Defenders. The tire I replaced them for were Michelin Pilots & I'm sure the Pilots were the OEM tires. The sticker on the drivers door says to set the psi to 33 & I believe the same psi was listed on the sidewall of the Pilots. I bought the new Defenders at Costco & when I drove off the lot & checked the tire pressure using the onboard menu, the pressure on all 4 tires was 38. The sidewall on the Defenders says 44 psi. What does everyone think I should set the tire psi to on these Michelin Defenders? Thanks Quote Link to comment Share on other sites More sharing options...
Marcyang Posted September 21, 2019 Report Share Posted September 21, 2019 The pressure showed on side wall is the max for the specific tire. You should follow the pressure showed on the doors stickers of the car Quote Link to comment Share on other sites More sharing options...
dommm Posted September 21, 2019 Author Report Share Posted September 21, 2019 31 minutes ago, Marcyang said: The pressure showed on side wall is the max for the specific tire. You should follow the pressure showed on the doors stickers of the car Thanks Quote Link to comment Share on other sites More sharing options...
Npahlavan Posted November 29, 2019 Report Share Posted November 29, 2019 My tires show 40 Max psi and inside the door it says 36 psi. So I set my tires to 36 but when I drive the TPS shows 40 (tires heating up). Should I be worried? Quote Link to comment Share on other sites More sharing options...
EastTN Lex Posted January 1, 2020 Report Share Posted January 1, 2020 Nope...tire pressure on the door label is the recommended cold tire pressure. Perfectly normal for the tire psi to go up as the tire gets hotter. Quote Link to comment Share on other sites More sharing options...
