Pioneer Cd Changer Removal
  • 6 months later...
Do you have instructions for the Trunk mounted changer 1996 es?
there are 2 large 14mm bolts 5that bolts it to the floor front of the flip down door and back for the large bracket. there is a little bracket arm are off the back right rear corner hooks into the quarterpanel brace behind the left side carpetring with a 10 mm nut , 2 connectors to remove and the wire attachment to the top bracket lid.
