I installed an aftermarket remote start module about 6 weeks ago.  Very unhappy with it, if you start it remotely, the engine shuts off (as designed) as soon as you open the door.
Has anyone installed one of these units, And do you have the same experience?
I suppose apart from any liability of the engine not shutting off when the door opens, you could always disconnect the connection to the drivers door switch therefore not allowing it to shut down the engine.
What liability of the engine not shutting off are you referring to?  If I were to start the engine conventionally, exit the car, then open the door to re-enter, the engine does not shut off.
