The weatherstripping came off a few years ago on my 2006 RX400h's rear hatch door.  (Moving big items in and out rubs against it, it's inevitable it seems if you use it for cargo!)
I got away with a few years of using the black goo glue to put it back in place, but now it's in tatters and stretched and it's done.  I need to replace it.  The hinge for the hatch door seems to stop the new weatherstripping from going on easily - does anyone know if this is a DIY job?  Thanks for your help.
Got the Chilton (thankfully from my library) and it's got literally nothing on weatherstripping replacement (doors or hatch).  So that was useless....
The parts person at your dealership can show you (and maybe print out) an exploded view of that assembly. Some online dealership websites contain the same thing, but with lower resolution images.
  • 5 years later...
What did you end up doing? Same problem here, hoping to fix cheaply instead of replacing it. What glue did you use for your temporary fix? Thanks!
3M makes an adhesive called 847. It is specifically for bonding rubber/gaskets to a variety of materials. It is also fuel and oil resistant. It comes in a 5 oz tube (brown in color).
