anthonyinit Posted May 14, 2017 Posted May 14, 2017 Hello all, Please can somebody help me the correct OEM parts to replace ADUS 505 Bushing. i need to change my Ls400 Rear Carrier Arm Bushing. kindly check the image i have attached. thank you all
sha4000 Posted May 14, 2017 Posted May 14, 2017 What year is your LS? This thread should help. https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/236651-rear-knuckle-bushings-source-pic-attached.html
anthonyinit Posted May 14, 2017 Author Posted May 14, 2017 Thank you for ur reply my lexus is LS 400 91' i guess well now it is confirmed there there is not OEM to replace Adus 505 . :)
The Wrench Posted May 17, 2017 Posted May 17, 2017 many companies offer aftermarket solutions. not sure what is close to you. but look into "Superpro" bushings on ebay. they make almost any bushing you could ask for. an email directly should get your needs sorted.
anthonyinit Posted May 26, 2017 Author Posted May 26, 2017 thx i will check for "Superpro" hope i can get what i need.
