I got check engine error p-0325 bank 1
i changed sensor still same problem
anyone help plss
how it can be recover ?
 Hi...it could be the wiring loom faulty or interference from ignition to the knock sensor (move the wiring away from other leads on the engine)
  • Like 1
If it is interference bleed over into the sensor, then move the wiring away from anything else (such as Ignition Leads) or insulate with tin foil and earth out...usually does the trick
