Acceleration Problem
Gary J2
On two occasions recently, my 2016 RX has experienced an acceleration problem.
--  The first time, it occurred when I was backing out of a parking space at a Freeway Rest Stop. I started the car, put it in Reverse and let my foot off the brake, to "creep" out. Nothing happened. I pressed the accelerator a bit and still nothing. I pressed harder and nada. I put it in Drive and it inched forward a bit. I again put it in Reverse and removed my foot from the brake and everything worked normally. No warning lights appeared on the instrument panel.
--  A few weeks later, I started the car normally, put it in Drive and pulled from the curb parking space into the traffic lane. The damned thing wouldn't accelerate and I almost got rear-ended. The speed topped out at 8mph, according to my HUD. A yellow warning triangle, over the 80mph marker on the speedometer lit for about a half-second. The Dealer couldn't duplicate the problem on a test drive (one round trip from the shop of about a mile) nor were there any codes stored in the diagnostics unit.
Has anyone else experienced an acceleration problem? (NOTE: The car is always in the Normal driving mode. I never use "Sport" or "Econ" Modes).
Thanks
Hi Gary
It does sound like the transmission is not engaging correctly and applying full hydraulic pressure....could be a sensor issue.
I would definitely take it back to the dealers to run more tests as this is quite a dangerous occurrence by the sound of it
Keep us update on how this progresses
Cheers  Trevor
  • 4 months later...
