Speaker/amp Problem?
terrimac
I think your speakers are blown as I have looked at my stock speakers in my car and both the speaker and tweeter run off the same wires. My car is also a 91 LS400 with the Nakamichi system in it. Or maybe you can remove your speakers and check for connection problems. Good luck
Yes, all the speakers are dead except the tweeters. A tech at one of the dealer locations suggested the amp. I have had a bit of a problem with water pooling in the trunk, but it didn't appear to have been in the area of the amp and cd changer.
Also, the drivers door lock broke at about the same time the speakers went out. The dealer repaired the door lock, but just said that the speakers aren't working.
