Rx300 Gas Mileage
sgriffith
I am getting about 19 MPG on my 99 RX300...about 76,000 miles....98% of the miles are highway. I use regular unleaded, have recently changed the spark plugs & air filter. Is this about what everyone else is getting...better or worse? Is there anything that I can do to get a little better gas mileage? When we got it it was getting around 21 - 23 MPG but has dropped off in the past year or so. Thanks in advance for the advice!
I'd be interested in hearing more on this. I have a '99 RX 300 as well and according to my Info screen, I'm getting, at best, 15 MPG. However, I have two bad O2 sensors, which are being replaced this week. I was told that those will affect gas mileage.
Ok, I'm in the middle of you guys. I've got a 2001 RX with almost 60K
(had them do my 60K service before I bought it). I'm getting about 18mpg
but most of my driving in local. And yes, Doug, you should see somewhat
of a boost in your mileage after they replace the O2 sensors. Maybe not
a lot, but some at least. The other thing that might be interesting is your
quality of gasoline. I don't use high-octane, but I do use either Mobil, or
Sunoco, or one of those v.s. an off-brand. Tried using one of those cheaper
brands, and unfortunately it only took a tank or so, I found my climb over
the local mountain seemed less energetic.
PharmGuy
The Toyota Highlander shares the same V6 engine as the RX300:
Here's a Highlander owner testimonial about the effect of octane on gas mileage:
Subject: Re: [Toyota Highlander Club] Fuel: change from Premium
to Regular
Date: Tue, 27 Apr 2004 20:28:23 -0700 (PDT)
Reply-To: toyotahighlanderclub@yahoogroups.com
I notice a degradation of performance and gas mileage in
my 2002 V6 (with 41000 miles) when I use regular (87)
vs. premium (92). With higher prices, I switched to
87 and routinely got 1.5 to 2 mpg less than with 92.
Performance suffers as well. After refilling with 92,
performance improved and I'm back to 20-22 mpg in
mixed city/highway driving in Charlotte NC.
Hey monarch,
Interesting info from ToyotaHighlander Group. If the price does go down,
I might try it again. Unfortunately, I think when I ran a couple of tanks of 93
octane, I didn't give it enough time to change. But, certainly, thanxs for
the imput.
PharmGuy
