Antenna wont totally go down.
Jamoy
Most likely it is the retractable antenna mast.  It has a coiled nylon "tail" with teeth that allow it to be pushed up and retracted back.  I'm pretty sure some of the nylon teeth have broken off.  The following video will show you how to replace your mast.  It's actually a pretty simple job.  Just pay attention and take your time.  New mast is available at your friendly Lexus dealer Parts Department.  As repairs go, this one is pretty easy and not that expensive.  I did mine  a few years ago and this is the procedure I followed.
Good luck.
