Smokey68 Posted July 6, 2016 Share Posted July 6, 2016 I just bought a used 05 ls430 with 88,000 miles. Two owner, good service . ,paid 16. Question , did I get a fair deal? NOw that I have the car ( wich I love) are there any things I should have inspected,or serviced? any help would be greatly appreciated 1 Quote Link to comment Share on other sites More sharing options...
nedear Posted July 7, 2016 Share Posted July 7, 2016 Congrat on your new ride, I also bought mine at local Lexus dealer for an 05 86xxxK miles for 19k OTD, so if your 16k OTD then it's a good deal. What you can do is check the service history by registering the vehicle at Lexus Owner website, you will see the previous owner's service record the most important is check that timing belt and water pump service has it been done yet. I love the 3rd GEN LS, everything inside are so refine, love the ventilation seat and replaced the seats blower air filter (it hasn't been replaced over 11+ years), this is the car I really want to buy 10 years ago, I did some minor maintenance like oil change, spark plugs changed, air filter changed, car run so smooth and refine, next is rear differential gear oil, I will let dealer change the ATF fluid since it require using Techstream software to monitor the fluid level. I just added an iPod adapter from VAIS and the Mark Levinson sound so lively with the iPod. 1 Quote Link to comment Share on other sites More sharing options...
Smokey68 Posted July 7, 2016 Author Share Posted July 7, 2016 Thanks for your reply!!! It means a lot!!! Im checking on the seat filters now,and making an apt for the atf. the I pod adapter is next. I have the exact car you do. ,that's great take care . W.m.harris Quote Link to comment Share on other sites More sharing options...
nedear Posted July 8, 2016 Share Posted July 8, 2016 Hi William, So you have the same color I have Briarwood Pearl? Mine also 2 owners and I am the 3rd, the seats filter is underneath the seat, very easy to access to. 1st, raise the seat to highest possible position. 2nd remove the small tiny drawer (slide open, push down and pull) then you can clearly see the filter attached to the blower motor. here is where I bought it from and they are quick shipping. http://www.ebay.com/itm/231669122805?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Don't forget the cabin filter also inside the glove compartment, I found out mine trap lots of pine pin in it. here is the seat filter (new vs old) The VAIS Tech iPod / USB adapter I place it inside the glove compartment, all of the control just as CD changer very convenience. Let me know if you need detail removal the radio and trim to install the VAIS adapter. 1 Quote Link to comment Share on other sites More sharing options...
Smokey68 Posted July 8, 2016 Author Share Posted July 8, 2016 10 minutes ago, nedear said: Hi William, So you have the same color I have Briarwood Pearl? Mine also 2 owners and I am the 3rd, the seats filter is underneath the seat, very easy to access to. 1st, raise the seat to highest possible position. 2nd remove the small tiny drawer (slide open, push down and pull) then you can clearly see the filter attached to the blower motor. here is where I bought it from and they are quick shipping. http://www.ebay.com/itm/231669122805?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT Don't forget the cabin filter also inside the glove compartment, I found out mine trap lots of pine pin in it. here is the seat filter (new vs old) The VAIS Tech iPod / USB adapter I place it inside the glove compartment, all of the control just as CD changer very convenience. Let me know if you need detail removal the radio and trim to install the VAIS adapter. Thanks for your reply!!! It means a lot!!! Im checking on the seat filters now,and making an apt for the atf. the I pod adapter is next. I have the exact car you do. ,that's great take care . W.m.harris Quote Link to comment Share on other sites More sharing options...
Smokey68 Posted July 8, 2016 Author Share Posted July 8, 2016 Thanks for everything, you have been verry helpful . Quote Link to comment Share on other sites More sharing options...
