vinnyp Posted June 3, 2016 Share Posted June 3, 2016 I tried to find the answer on previous threads by no luck…please humor me I have a 2007 400H Driver’s side window controller controls all windows EXCEPT the right rear All windows can be controlled by it’s dedicated controller on the door I did notice that when I try to close the window I have to push it all the way down ..if I let go window stops…it will not operate when I simply tap it down…. When opening window I have to pull it all the way up(auto?) but it will stop if I let go..it will not work at all if I simply toggle it up All the green LEDs on drivers panel are lit BUT the LED on affected window is not lit FYI I have not removed the battery nor is it dead..I have been driving it around all day yesterday and today Lack of LED on affected door switch has me wondering…HUMMM? Thanks for your help Quote Link to comment Share on other sites More sharing options...
Timothy Stephen Bush Posted June 3, 2016 Share Posted June 3, 2016 I had the same issue with my front passenger side window over the winter. Pop out the affected window's switch (i.e. the rear passenger switch), disconnect the switch from the wiring harness then reconnect the switch. Turn the car on and check to see if it can be controlled from the driver's console. Quote Link to comment Share on other sites More sharing options...
psycle_1 Posted June 13, 2016 Share Posted June 13, 2016 Roll down the window at the affected door's switch. Hold the switch down for a second after it has rolled all the way down. Then roll it back up, again holding the switch for a second after it has rolled up. This should relearn the anti-pinch function on the window and it should work again at the driver's panel, along with all auto functions. Quote Link to comment Share on other sites More sharing options...
mkymkcordes Posted November 29, 2017 Share Posted November 29, 2017 Do this twice to the window then recheck the driver's control panel to see that it has reset Quote Link to comment Share on other sites More sharing options...
