I have an 06 RX 400H.  I bought the truck in 2011 and since then have purchased 2 batteries for it.  I do use the auto light feature and I have auto start could these two things be draining my battery while the car is off?  Or could it be the smaller battery that needs replacing?
Suzanne, I would hazard a guess that there is and has been a grounding problem w/ your vehicle. I think 2 batteries in 5 yrs. is one too many, so it is probably time to take it to a good mechanic to find the problem. Good luck!
The auto headlight feature should NOT drain the battery. If you are referring to "Remote start", then there is a chance that it was wired incorrectly. An auto electric shop should be able to isolate the problem, quickly.
It is possible that you just need your battery leads and connectors cleaned and tightened.
