Jsweets Posted December 25, 2015 Share Posted December 25, 2015 I have my 2002 IS300 5 speedcar has been running great %100 stockrecently It started misfiring real bad,Codes that have come up are as followsP0301 Cylinder #1 — Misfire Detected P0302 Cylinder #2 — Misfire Detected P0303 Cylinder #3 — Misfire Detected P0304 Cylinder #4 — Misfire Detected P0305 Cylinder #5 — Misfire Detected P0306 Cylinder #6 — Misfire Detected P0300 Random/Multiple Cylinder Misfire Detected There was also a bank 1 o2 sensor upper CEL as well but i dont remember the codeWith that being said i have replaced common items that can cause this.Sparkplugs with OE NGK IridiumSparkplug wires NGKCoil packs OEMbank 1 o2 sensor, same denso as OEMWith all this the car still throws the same codes and im at a loss, When car is cold it will start run just fine until it warms up,As soon as it warms up all this starts to happen.Any help on this would be greatly appreciated! Thank you in advance!! Quote Link to comment Share on other sites More sharing options...
IanH Posted December 26, 2015 Share Posted December 26, 2015 A quick look as FSM says you should do this next 5. INSPECT CAMSHAFT POSITION SENSOR (a) Disconnect the sensor connector. (b) Using an ohmmeter, measure the resistance between terminals. Resistance: Cold 835 - 1,400 W Hot 1,060 - 1,645 W If the resistance is not as specified, replace the sensor. © Reconnect the camshaft position sensor connector. 6. INSPECT CRANKSHAFT POSITION SENSOR (a) Disconnect the sensor connector. (b) Remove the bolt holding the connector bracket to the water pump. © Using an ohmmeter, measure the resistance between terminals. Resistance: Cold 1,630 - 2,740 W Hot 2,065 - 3,225 W If the resistance is not as specified, replace the sensor. (d) Reinstall the bolt holding the connector bracket to the water pump. edited to try and get back readable format. (e) Reconnect the sensor connector. Quote Link to comment Share on other sites More sharing options...
IanH Posted December 26, 2015 Share Posted December 26, 2015 Also check the water temp sensor. Are you saying that if you clear the codes with a code reader its fine unit it gets hot then codes reappear ? Quote Link to comment Share on other sites More sharing options...
Jsweets Posted December 26, 2015 Author Share Posted December 26, 2015 When I clear code then start the car, the CEL comes on immediately (cold or hot) but when the car is started from cold it will run fine (even with CEL on) until it warms up I will get my meter out and check those sensors tomorrow, :) hopefully i just need to replace one, clear codes, and be on my merry way Quote Link to comment Share on other sites More sharing options...
IanH Posted December 27, 2015 Share Posted December 27, 2015 So it could be the water temp sensor. download the FSM it will help you a lot. Look on forums for link Good luck. Quote Link to comment Share on other sites More sharing options...
Jsweets Posted December 31, 2015 Author Share Posted December 31, 2015 ok after pulling off several sensors checking them putting them back on, the sensors checked fine all in good standing. After putting them back on a miracle code popped up, its a P0011 Intake camshaft position timing Over-Advanced (bank 1) I tried looking this up but all I can find is information all the Crank position sensor. Are these the same thing? Can someone point me in the right direction? Also downloading a FSM isnt as easy as you mention it as the link on this forum is dead, along with (myis) and clublexus (404 not found) but with that being said I may just be literally computer compliant lol Quote Link to comment Share on other sites More sharing options...
Jsweets Posted December 31, 2015 Author Share Posted December 31, 2015 here is a pic of the code Quote Link to comment Share on other sites More sharing options...
IanH Posted January 1, 2016 Share Posted January 1, 2016 ok. send me your email via PM and I will send you a link to my copy. will look up code and reply. Quote Link to comment Share on other sites More sharing options...
IanH Posted January 1, 2016 Share Posted January 1, 2016 Looks like you need DI-53 on as well as FSM does your code reader have freeze frame ? Quote Link to comment Share on other sites More sharing options...
Jsweets Posted January 2, 2016 Author Share Posted January 2, 2016 if the code reader had freeze frame Im unaware of it also Im not sure what you mean by DI-53 Quote Link to comment Share on other sites More sharing options...
