Indicator Lights For Adjusting Rear View Mirror Are Out.
cltractor
The lights are out on the adjustment buttons for the rear view mirrors. Is this a blown out fuse? Thanks in advance for any and all responses!!!!
If none of the other illumination bulbs are out, your issue is a probably a fuse...it could also be a defective switch, but a bulb is FAR more likely.
Hi, I am being confused. Please describe your issue precisely if you want to receive any support at this forum
"lights on the adjustment buttons for the rear view mirrors"...
A little switch...driver's side...lower portion of the dash. You press the buttons and the mirror things on the outside of the front doors move in and out and up and down... :rolleyes:
