HotBlue400 Posted April 21, 2004 Share Posted April 21, 2004 my 98 gs400 only has the factory lexus stereo.. no Nakamichi or levinson.. is it worth trying to find the Nakamichi? i do have nav.. or should i just add an eq and some good subs and an amp. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted April 21, 2004 Share Posted April 21, 2004 Mark Levinson wasn't available in the 1998, Nakamichi was. It's no easy task to replace the standard Pioneer with a Nakamichi. The amps, wiring, and speakers are also different. Quote Link to comment Share on other sites More sharing options...
philip frank Posted April 22, 2004 Share Posted April 22, 2004 are you saying that the stock stero in a 98 gs is made by pioneer? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted April 22, 2004 Share Posted April 22, 2004 Absolutely, 100% yes, as are the speakers and amp as well. I just ordered a replacement LCD display for my '98 radio directly from Pioneer. They are quite easy to deal with concerning parts. Click here for Pioneer Parts I'm not sure of the manufacturer of the navigation system, but I would assume it is also Pioneer. If you pull your radio, it says Pioneer right on it along with the part number of the radio. Quote Link to comment Share on other sites More sharing options...
philip frank Posted April 22, 2004 Share Posted April 22, 2004 is the amp built into the radio or is it a seperate component? also, what are the wattage specs and what can the stock speakers handle on the stock 98gs stero? Quote Link to comment Share on other sites More sharing options...
HotBlue400 Posted April 22, 2004 Author Share Posted April 22, 2004 so than the best thing for me would be to just add an amp and sub, and maybe replace some of the factory speakers with aftermarket? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted April 22, 2004 Share Posted April 22, 2004 Amp is seperate, under the dash. Amp is rated 215W max. Individual speakers are 2 ohm (front) and 4 ohm (rear), wattage unknown. Good luck finding matching aftermarket speakers with the proper impedance for both the front and rear locations. Am I the only one who thinks that the factory system sounds pretty good (7-8 out of 10 IMHO) for a factory system? Albeit, it could use a little stronger low-end. I guess it depends on what you're listening to and who you're trying to impress. B) Quote Link to comment Share on other sites More sharing options...
