Valve Gasket Leak - Repair
prix
Need to know if you have to remove the liner underneath the car (it protects the engine from road grime) to do this repair -- a valve gasket repair. Or can the repair be done without taking off the liner? Trying to figure out whether my damaged liner was caused by a mechanic removing/replacing it during this repair. Thanks for your comments.
should not have to remove in order to replace valve cover gaskets they are on top however sometimes removing the cover helps visibiility while working on top and it can be removed in 5 minitues so it is possible they removed it
