rd122481 Posted April 8, 2004 Share Posted April 8, 2004 Does anyone have a copy of "the manual" to swap the 2JZGTE into the Lexus SC300 that they would like to sell? A gentleman from Hawaii was the author. E-mail me @ rd122481@hotmail.com Thanks. Can anyone give me any info: I want to buy a SC300 5MT and swap in the 2JZGTE motor and keep the Lexus 5speed. I know that combo will work, but I'm unsure about the clutch holding up. Can I use a flywheel and clutch for the Supra TT in that setup? Thanks again! Quote Link to comment Share on other sites More sharing options...
AWJ Posted April 8, 2004 Share Posted April 8, 2004 You should buy the manual directly from Phil. He did the hard work for you to follow if you choose to do so. There are no other copies. His site is linked in the faq. Good luck. You will need to use the clutch from the 5 speed as the TT clutch is different and only works on the 6 speed. Not sure about the flywheel. I would think you can use either. Quote Link to comment Share on other sites More sharing options...
Lextreme Posted April 10, 2004 Share Posted April 10, 2004 That manual is copy righted and no one will be able to supply you the manual. I got mine from Phil. Read it and sold it. Quote Link to comment Share on other sites More sharing options...
