Disconnecting Battery
LEXIE
Are there any precautions in temporarily disconnecting my battery other than
negative cable first. Will I foul computer system up and if so how do I restore
previous settings after reconnecting.
'93 SC400
You won't ruin the computer or anything, anything that actually requires work needs the battery replaced... You will loose your radio settings of course, but that is about it. And you might see a slight performace increase while the ECU relearns fuel curves and such. But it won't last long.
Long story short, you won't ruin anything... But if you have a stereo that needs a code after reset make sure you know it first, I am sure lexus charges an arm and a leg to look it up. (much like mitsubishi does)
Hook a battery charger or another 12v battery to your cables before you remove them, then you won't lose any of your settings. I've heard of people using a little 9v battery to do the same thing (preserve settings.)
I think there are even little battery systems you can buy that plug right into your cigarette lighter and do the same thing of maintaining radio memory and all that business. I don't remember where I saw them though, sorry :unsure:
thx for all the replys guys. the reason i asked the quest was because
i was going to replace the seals in my p/s unit and needed to disconnect
the bat.
regarding the p/s job, although it took me yesterday and today, all went
well and because of all the info here and on other sites there were no
big supprises. of course the infamous two back bolts were the biggest
deal. i was able to remove the pump under the hood but when replacing,
i couldn't keep the lower back bolt from falling out before i could get it
started (threaded) so i fianlly had to jack the car up and go in from
underneath.
i also thoroughly cleaned the reservoir out and a quite a bit of s**t
came out. after installing the rebuilt pump i purged all the old fluid out and now i am in the process of deaerating the new fliud in the system. the pump is getting smoother with each cycle of starting and rotating the wheels to complete stop, left and right.
i hope all holds up...it feels good to save some $800 bucks after all is
done.
thx again to all for the many questions that were answered.
lexie.
ps... the solo drive belt removal and replacement was a snap as one of
the previous posts stated it would be.
