Bryan:
Please email me a copy. I have a RX 300 2000. Should be the same.
rgarysears@mindspring.com
Thanks
Gary
Anyone need thease hard to get wiring diagrams just let me know and i will email the 1 u need...:cheers:
Thanks,Bryan
  • Replies 219
  • Created
  • Last Reply
Top Posters In This Topic
Thanks,Bryan
Bryan,
please send me the wiring diagram for the radio and antenna...im stuck
email: jsandric@gmail.com
thanks,
john
Bryan or someone else.....
I need RX300 2000 wiring to find a connector for brakes light to connect to trailers plug. I looked into obvious places, however could not find anything. Any advise on this matter will be greatly appreciated. Please email me bbelenky@yahoo.com
I am also looking for this information for 2000 RX300. I have the tow prep package, but also could not find anything. email is jfriel@opgate.com Any help is much appreciated
Thanks,Bryan
If it wouldn't be too much trouble, I could really use a copy. My email address is: jason.maglovsky@gmail.com
Much appreciated, jason
I would really appreciate the wiring diagram for the ac system. Mine decided to quit working. Thanks.
tjrudolph@hotmail.com
My side mirrors are not working- I think the radio #2 fuse is the correct one but not sure- if you have a diagram please send- 2000 RX-300.
lwaberne@tycoelectronics.com
Anyone need thease hard to get wiring diagrams just let me know and i will email the 1 u need... :cheers:
Thanks,Bryan
I need wiring diagrams on the brake lights. (hot wire not hot & had to borrow hot in juction plug on left rear inner panel to get brake lights to work)
I pluged in a trailer that was grounded out and instead of burning fuse out in dash....it must have burned an inline fuse to that junction plug. But, I don't know where to look and the lexus dealer doesn't get it at all.
Any wiring diagrams that would address this issue would be greatly appreciated. I have fax or email....not sure how to give you it without advertiising it world wide. I'm brand new here.
Thanks, Rogerlexus
Thanks,Bryan
Bryan,
I am at a loss with my lexus rx 300.
I am looking for the complete diagram, the vehicle has no power (radio, ac brake lights etc ) inside ( it is stuck in gear) but it runs. go figure.
Thanks,
Mike
my e-mail is fidelityholdings@gmail.com
I'd like a copy of the electrical diagrams also. The turn signal lights on the outside mirrors are not working. Is that in your diagrams? I guess they are OEM, but I don't know for sure, I recently purchased the car. 2001 RX 300
Thanks
My cennter consle cluster does not lit up, garage openner stopped working, and LCD panel went black once I tried to warm my butt. Fuses looked OK. I guess it is wiring. please forward the diagrams to minsk73@yahoo
Thank you.
Thanks,Bryan
I could do with a copy. Thanks!
scottdw77@gmail.com
Could I get the diagram for the RX300 Tail lights? Brake lights work and the side marker lights work... Just NO tails... Not sure what is going on here.. Power to the relay and then to the fuse in the panel... Must be losing it somewhere else in the harness. It is a 2001
Please email to Mxz71@hotmail.com
Thanks
Please send me diagram of the headlight wiring
Thanks
Hi, did you ever get headlight wiring diagram???? I'm looking also, no luck so far... thanx, rogggair@aol.com
Thanks,Bryan
I would appreciate if you send me one shows the detail wiring for headlight.
Rgds,
icjkang@yahoo.com
Hi, looking for low beam headlight diagrams, 99 rx300. thanx... Rogggair@aol.com - anyone????
Hi, did you ever get headlight diagrams????
Thanks,Bryan
Can you tell me where the relay for the tail lights on the 99 rx is located? I blew mine with a bad trailer connection and replacing the regular fuse and tail light bulbs didn't solve anything. I understand there is a relay for the tail lights, but I don't see it labeled in any of the fuse boxes, under dash or hood.
Thanks,
Brian
