nelks Posted November 7, 2014 Share Posted November 7, 2014 Hello all. I recently found out that my oil pan gasket was leaking and needed replaced on my 2004 RX330. The quoted price to repair was $350. However, I am pretty handy (change my own oil, rotors/brakes and wrote a tutorial on replacing the hub assembly) and was wondering if anyone can comment on how difficult a job this is? Outside of removing the sheilding underneath that is covering the oil pan, is there anything that would make this a difficult job that would warrant having a mechanic repair it? Any comments are appreciated. I also supposedly have an axle seal leak. From what I read, that job was a bit more complicated. However, if anyone has any insight into that job as well, please feel free to comment. :) Thank you in advance! Quote Link to comment Share on other sites More sharing options...
bayray Posted November 7, 2014 Share Posted November 7, 2014 2009 Oil pan gasket replacement required special Lexus sealant material and time to dry. you need a lift... local shop repaired mine <$100. Quote Link to comment Share on other sites More sharing options...
nelks Posted November 9, 2014 Author Share Posted November 9, 2014 Thanks. Quote Link to comment Share on other sites More sharing options...
