LexDean Posted October 13, 2014 Posted October 13, 2014 Just got my 06 GS430 with 153,000 one owner miles. Timing Belt has never been changed. It is parked until Monday when I can get the service done along with the water pump and idlers, etc. Can anyone top this? Or is this a record (dubious albeit) on how long a timing belt has lasted? Curious if anyone has gotten more miles than this on theirs.
sailwindtwo Posted October 13, 2014 Posted October 13, 2014 I have 109k on my 2005 LS430 and I'm trying to get the time to have mine done now. I don't go on road trips right now because I dont feel confident enough until I get it changed. I've had my car since it had about 35k on it and it's not been changed yet either.
VBdenny Posted October 13, 2014 Posted October 13, 2014 I had the timing belt changed at 92,000 miles on my ES330. It looked perfect when it came off. I suspect the timing belts could go 200,000 or more. Of course I would only try that with a non-interference engine.
kevin3344 Posted October 14, 2014 Posted October 14, 2014 I have a '99 GS400 and I had my timing belt changed at 120,000 miles. I now have about 206,750 miles on the car and it runs great. I'll probably have it changed again at 220,000!
LexDean Posted October 17, 2014 Author Posted October 17, 2014 I need to update my post. I found that my belt HAD been changed properly at 100,000 miles. I will try and post pictures of what the belt looked like and found the mechanic from the original owner (not the Lexus Dealership) saved $1000 by taking it to a good local shop. This is why it did not show up in service records. I had bought kit to change belt and had started the tear down when I discovered the following which led me to research further the service on this beautiful one owner Lexus, which led me to find it had been changed. I was doing the work to change it, I pulled my Cam Inspection cover off the top left front side of the motor. Very large cover which allows a very good look at the timing belt. It still had good white print/ imprinting on the top of the belt (non grooved side), I have established that this white print (arrows, CR, LC, RC, plus TOYOTA and numbers) wears off completely at about 70,000 miles. So if I had white print, AND the belt looked good, could it still be the original belt after 153,000 miles? I concluded that no it could not be the original belt after that kind of mileage. Plus I could tell unmistakably that the crank bolt and thermostat housing HAD HAD A WRENCH ON THEM!!!!! All this evidence led me to call the original owners one more time and pull some more information out of them. So it appears I have saved myself quite a bit of work and money here.
1990LS400 Posted May 10, 2015 Posted May 10, 2015 Depending on model and engine, timing chains were introduced beginning with the 2006 model year - IIRC.
