Turn Signal Light Replacement
my driver's turn signal on my 2000 ES 300(platinum series) is blinking about twice as fast as it is suppose to. the manual says that means one of the turn signal bulbs is bad. my question is, how do you get to the light in the front to check and/or replace it?
if it is anything like my 94 headlight the bulb is acessed from underneath
the headlight assm
or take the 3 bolts off the whole assm and pull it out that way
one of the 97-01 owners might give you a better idea if it is that way
( it really is an odd way to put a bulb in)
