Steering Wheel Stuck
Wes
Guys,
I got in my Lexus LS 400 94 on Tuesday and the steering wheel did not rotate down and into position so it is now stuck. What do I need to do to fix it?
Driving an erected steering wheel????
Sorry about the graphic picture but guys will know what I am saying!! :blink::blink::blink::blink:
Is this one of the early LS's with an On-Off button on the left side of the steering column? Did the tilt feature get turned off? Or maybe the switch is bad. Have you checked all the fuses? The worst case would be if the tilt motor had gone bad. My recommendation would be to look at the on-off switch first if it has one and then the fuses.
