both front corner lights are out at the same time. Is there a single fuse for them? Where? BTW, blinkers do work.
Do you mean that the hazards work in the front but when you signal to turn the front signal does not work? If so I think there would be a problem with the stalk on the steering wheel.
No. I mean the front corner marker lights don't stay on with the headlights. The blinkers and hazard lights do blink.
Are you talking about the 2 orange lights on the side of the fender? I deleted those years ago when I put a custom bumper on. If you are talking about the lights right next to the headlights they are only for turn signals and hazzards they don't stay on with the headlights.
Thanks, Craig. Yes, meant the corner lights next to the headlights. Strange, that they are not required. They are on every other car I've ever seen. They are required on my Semi. Anyway, good to know before I started tearing things apart.
