Hi there,
TPMS light for RX350 does not go off. i have got the tire pressure checked and it has the correct pressure now. But the warning light is still there even after driving almost 50 kms.
As per manual, the TPMS needs to be checked. Does anyone have the same problem?
Thanks,
harry
This may seem rediculous, but is there a TPM in the spare tire?
Yes, there is a TPM in the spare tire.
Just drop the spare, top off the tire pressure, and I'd bet a bunch that the light goes off. The voice of experience here.
thanks- i will definitely try putting appropriate pressure in the spare tire. I will definitely revert with my result. Thanks for such a good hint.
Yes the spare tire sometimes leaks air. Fill the spare tire first it could save you from paying someone else to try to figure it out.
I put air in the spare tire and no more TPMS warning light. Thanks a lot to GDixon and JJsCarAudio. You guys are amazing!
Thanks for reporting back as you said you would!
