Engine died while driving and wouldn't start again. Found crankshaft pos sensor had fallen off. It connects to a place near the underside of the oil pump pulley, and I could find nothing online of where it's located.
this should help,item # 15100r on scan... seems like you could just get under it and see where it goes..
post-5365-0-41433400-1408490544_thumb.jp
I replaced the sensor and cleaned the connector, but still has code 12- RPM signal no.1 and won't start.
No, everything was fine until old one fell off. Got it running now, but seems to be missing a clyinder and has the same code.
