Lexus 1996. 140,000 miles
Always we'll maintained.
Distributed , rotors and spark plug plus cables changed at 90,000
PROBLEM :Last week during rain the car stopped , but started in five minutes.
Last week , I changed the battery
yesterday the car idled rough as if on only 4 cylinders
I shifted to neutral and gunned the engine. The car became smooth again
What gives?
M khan
I
Is your check engine light on? If the cylinders were not firing properly it would trigger a code. If so go to aotuzone and they will pull the codes for free and give you a printout of the codes with a slight description, Then let us know what they say.
If you changed the battery because the old one was weak (maybe dead?) there is a good chance that the ECU was relearning fuel settings that were lost when the battery was out. That may be the reason for the temporary rough idling.
For now, just keep an eye on it and let us know if the rough idle returns.
